- May 3, 2014
- 62,727
- Fiberglass
- Pentair Intellichlor IC-40
For future FC testing, use 10 ml water sample, 1 scoop of powder, and each drop of reagent to clear is 0.5ppm FC.
CH still appears low. I would suggest you get a water sample from the taps that were used to fill the pool and test the TA and CH of that water.
How does the water look? You need maintain your FC in target range based on the FC/CYA Levels
Soon you should do a Overnight Chlorine Loss Test to see if you need to follow the SLAM Process
