Hi all,
To start, please ignore my CC results. They should be .2
This is my second year with this pool. 20k gl, inline trichlor puck feeder, cartridge filter. This is my second day using the TFP method. I use the Taylor K 2006c. My pool is in direct sun from sunrise to around 4 pm.
I am a long time lurker on TFP but didn't switch because last summer went so...swimmingly (sorry).
This summer has been frustrating due to the constant sun and heat. I have been unable to keep chlorine levels up.
Last Wednesday I noticed my pool was a little cloudy, I tested it and my pH was high. I added acid and within a day it was much clearer. I shocked on Sunday per usual using 1lb bags of granular.
Wednesday we tested the water at the store (results attached). I shocked it with 2lb. Usually the water clears up within 24 hours but it's still so cloudy. I panicked as I thought this could be the start of something bad and decided to fully invest into the TFP way. You can see my results from yesterday and today attached. I turned the trichlor off completely.
Questions. Is it normal to lose that much FC overnight? Am I on the right path by using liquid chlorine to keep it at the reccomended level in relation to my cya level? If so how long should it take to clear up? Do you think this could be related to phosphates? I did buy orenda 10k.
