My boyfriend has a pool that he set up late last summer so it was only swam in once and then a tarp was put over it for the winter (leaving the water in it). When he went to open it up this year about 2-3 weeks ago the water was still clear but in the process of taking off the tarp (because he tried to do it by himself....lol) some of the old yucky green water on top of the tarp went into the pool and turned the water green.....well as bad as it looked it didn't really take long for us to get the green to go away but it is so cloudy you can't see the bottom and I figure it has to do with getting the chemicals balanced because I've been trying forever to get them to balance and I just can't get it. I'm about to lose it and boyfriend, who doesn't care about having the pool and hates all the money I've spent in chemicals is about to double lose it....hahahaha
Here's some info. Pool is a 16' X 42" round vinyl pool. We don't have the cheap filters that come with it, we have a sand filter (not sure what kind) hooked up to it. The biggest problem I've noticed by using test strips is that of all the tests that I have done in just the last week (9 total) the stabilizer has read zero EVERY time but one and the Total Chlorine has read 10 EVERY time, no matter what any of the thing ones read. Also of the 9 tests I've done the Total Hardness and Free Chlorine have been in the ideal range 7 out of 9 times and the Total Alkalinity was in the ideal range 5 out of the 9 times. I think (from all the reading I have done in the last week or so) that it might have to do with the PH.....it has read 6.2 every time except for 3 times it read 6.8. I have even tried adding PH up a few times. Not sure if I'm just not getting enough in there or what because for example the bottle I have it says to add say 12 ozs......well I don't really have a way to measure it exact so I kinda guess with an 8 oz bottle.
I did read about adding stabilizer and added that throw the skimmer (like the directions on the bottle said....lol) 2 nights ago. I've read you can retest that after 48 hours but I've also read you should wait a week to retest it. So not sure if I should do anything more (with PH or chlorine) right now or wait out the time and check the stabilizer before checking anything else. I'm just at a loss as what to do. Boyfriend wants me to just drain it and forget about it but I don't want to. I had thought about draining it all out and refilling it with new water but boyfriend says that probably wouldn't help and would give us a huge water bill so as I said just not sure where to go from here....any suggestions would be GREATLY appreciated
