Hope somebody can help me. I've been on the BBB method for five years with great results but recently my pool has been cloudy and I can't figure out why.
Here's my test results:
CL: 7.5
CC: 0
PH: 7.6
CYA: 35 (this one is the most difficult to read, the black dot goes away 90% at 35, but I can always see a little tiny bit (maybe 5-10% of it) even when tube is filled.
ALk: 250
Calcium: 125
CSI: 0.2
It has been cloudy for the last 2 months. Since my chemicals seemed fine, my focus turned to the sand filter. I removed all the sand from my filter, checked all my laterals (which were fine). The sand itself was filthy (with small pieces of grass clippings coming out) when I took it out (even after a thorough backwash) so I figured I found the problem and though maybe the sand had some channeling going on. I put a hose in the water as I was pulling it out so the krud would float up and out the top of the filter. The resulting sand (which is about 3 years old) which I put in lawn mower utility cart, looked very clean. I let it soak in Kleen for a couple hours and then backwashed it thoroughly. When starting back up over the next couple of days it did clear up some but it has never been as clear as it used to. ie.... I used to be able to see the steps in the shallow end while being in the deep end - not it's just a haze.
It's not so bad where I can't see the bottom. Speaking of which, I've been getting the powdery dust at the bottom also. It's got a slight yellowish tint to it and the second I brush it, it dissipates. If I try to suck it up via a vacuum I attach to the skimmer, it will just return the following day. I tried vacuuming to waste before also and it just seems to keep coming back. I'll attach pictures.
My liner is 13 years old and due for replacement next year (has tears above water line) and I'll be draining the pool so I'll get to start from scratch, but I'm sure stumped on this one as of right now.
Also my solar cover is need replacement next year and has the bubbles falling off. (don't know if deteriorating solar covers would matter, that's why I'm mentioning).
I'll do an OLCT tonight but I don't expect to find anything since my daily chlorine addition has been about 60oz (it's on a Steiner pump injected).
Would the high Alk level cause the cloudiness? Thought I read somewhere that it didn't really matter since my PH has been really steady and I don't have a high CSI.
I'm on nasty well water, but I have a whole house filter (Big Blue filter) as well as a garden hose filter. https://www.amazon.com/gp/product/B00AXP8B9O/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
Thinking as I type, I did add a sprinkler system this summer, I wonder if somehow that is using up my Big Blue whole house filter and the water going into the pool is nastier than usual because of the excess water usage. I could try changing the filter out (I usually change every six months, maybe I need to go to every 3). Should I try some clarifier? I've tried staying away from all those "extras" over the years.
Any ideas?
Jamie
CL: 7.5
CC: 0
PH: 7.6
ALk: 250
Calcium: 125
CSI: 0.2
Any ideas?
Jamie
