Cloudy-ish water despite good numbers and little algae
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
32,863
Well, that's a little puzzling. A typical pool with a CYA of 50, would lose 1.5-2.0 ppm (roughly) so your loss is a bit excessive. Are you still using 6 ppm to 9 ppm as your daily range? Is your water still a bit cloudy? Got a pic?
Reactions: nabril15
nabril15
408
Miami, FL
Dave
The water looks immaculately clear. Yes, I am using 9 as my target FC whenever I go to add chlorine, which is as close to daily as my 2 jobs will allow.
borjis
3,032
Pacific NW
Did anyone ask yet...is your pool painted?
My first house/pool was painted a few years before I bought it.
It would rub off the paint every time I brushed and get a little cloudy....because of the paint wearing off.
I just thought with all the brushing you do, maybe it is related.
Reactions: nabril15
nabril15
408
Miami, FL
I have to clarify and apologize.
The title of the thread is from an issue that I had back in January. Since then, the pool has gone through slams and other issues. I finished my last SLAM with this thread, and I've used it a couple of times to ask general questions (as I did yesterday) that are unrelated to a cloudy pool.
duraleigh
Admin
Platinum Supporter
In The Industry
Apr 1, 2007
32,863
Actually, please keep the thread right here. Starting another thread almost always leads to more confusion.
So, if you have a pool with CYA 50 and crystal clear water and a successful OCLT, you should be in "maintenance mode" I know the FC/CYA chart suggests 6 - 8 ppm of FC but I would like to see you reduce that down to 4-6 ppm if you would like to control your daily burn at around 2 ppm FC.
If you don't really care about the 1 ppm savings (that's really pretty minor), I would suggest you keep doing what you are doing and go swimming!:)
