When you are running the pump, you are stirring up the white debris off the floor and making the pool cloudy.
That you have white debris is good.. It means the algae is dead.
I would vacuum to waste,
fill the pool,
run the pumps for an hour,
while pumping go buy bleach/chlorine (20 bottles?)
run a full set of tests
Adjust your CL to the SHOCK level based on the current CYA (using only liquid bleach/sanitizer)
Run the pumps 24/7 until you can pass the OCLT
Stop listening to the pool store
Read the Pool School some more
Research getting a good bleach/sanitizer injection system
Post your full test results here for help in making next decision
fill the pool,
