First time trying to balance the pool chemistry myself following the Pool company opening the pool last week.
Currently the pool is cloudy blue.
Pool details: in ground 30,000 gallons, Plaster from 1963 painted white by prior owner (dolphin is slowing removing the paint....), Chlorine, Sand filter, Variable Speed pump running at 2900 rpm, No heater, Dolphin cleaner, Cincinnati/Ohio USA
Took 3 days for the Dolphin basket to come back "Not full" of fines and other debris.
Water has been Cloudy blue all week.
Taylor test ppm results 5/18/23: FC 3.0, CC 0.4, pH 7.0, TA 60, CH 230, CYA 90, Leslie's test has Copper at 0.7ppm and TDS 700. Water sample for copper = 0.0, thus pool copper 0.7 must be coming from the algaecide during opening day.
Questions and learning:
a) Noticed the TA limits change between TFP 60-80, PoolMath 50-90, Leslies 80-120... with a Taylor value TA of 60, different limits will have me adding different amounts of Baking soda. Assume once I pick one, e.g PoolMath, stick to it for adjustments going forward
b) Will adjust TA, followed by CH, then pH last
c) How to achieve a clear water with no cloudiness....Is the cloudiness caused by Unbalanced chemistry, need to SLAM again, add a flocculant? Suggestions on how to proceed
Thanks, Carlos
Thanks, Carlos
