Hi everyone!
Wondering if anyone has any idea what might have happened in my spa today. I have been using the Bullfrog FrogEase chlorination system for about 6 months without any issues. Relatively expensive, but truly easy and works. Well, I put in a new Smartchlor cartridge about 2 weeks ago, but didn't notice a crack in the cartridge. Fast forward to today - the spa is sparkling clear, but pH is 3.3 and I find the Smartchlor is already empty!
Figured I should bring pH up with soda ash. Tried to measure TA with the TFT kit - solution was already red, which I assumed meant TA of zero. Calculated the amount of soda ash I would need (13 Oz), but then decided to only add less than half the calculation - 5 Oz (just in case). After I added the soda ash and circulated for a while, pH was up to 7.8 (despite adding much less than PoolMath suggested) AND the water started to turn cloudy. The water is now fully opaque, almost like skim milk.
I suspect I'll just have to drain and restart, but I'm just curious if anyone here has any idea what happened and if it can be reversed.
Thanks!
Thanks!
