In the spring I had the people who installed my pool replace the rubber type hoses connecting the pump, filter, and heater with PVC. The past several years those rubber connections would tend to pop off so that was a pain. As they were connecting everything I questioned how I was going to take my multi-port valve/ pump inside for the winter they said pool equipment stays outside all year. I requested they come back out and add a connector to have a way for me to get to my sand so I could deep clean it in the spring. I asked about the closing process and they said all I needed to do was run some RV antifreeze through the skimmer and when it comes back into the pool shut everything down and drain the pump, filter, and heater. I have attached some pictures of my current set up. I have been closing my pool since 2008 so a bit fuzzy on this change in process and I wanted to run it by the experts.
I have read various threads about hard plumbing, but these are my specific questions.
1) Should I have a plumber add connectors so I can remove my multiport valve and pump or does that just add another place for possible leaks when the pool is up and running again?
2) How much RV antifreeze should I add to my skimmer?
3) After I lower my water level below the skimmer, what about clearing the lines from/to the pool? I have read some threads about blowing the lines out, but what is the best way to do this?
Thanks for your assistance!!
