Hi, I have a small heated fiberglass pool with auto cover, I’ve read the closing guides and other threads and I can’t figure out my answer. I have these skimmers that the previous owner tiled on top of and I can only access them from the side. I wanted to use a gizzmo but I don’t think it will fit bc of the angle of putting it in. What are my other choices? Also I need to close the pool filled halfway up the skimmer in order to support the auto cover but I’m having trouble figuring out the best way to do that. Do I lower it below skimmer, plug the skimmer and then add water back to the half way point? I also read I’m supposed to drain below the tile line but I can’t do that and use my cover…. Buying a winter cover is not a choice bc one side of my pool is infinity edge and I have nothing to anchor to. What’s the smartest way to close my pool! Thank you!
