- May 18, 2023
- 97
- Plaster
- CircuPool RJ-45 Plus
I’m wanting to run my suction side vacuum and solar skimmer as my main cleaning methods. The only issue I see is that the main drain/skimmer share a line with the suction vacuum. Because they share a line, I have to close off the main drain/skimmer to about 75% at 2600rpm to match the advised wheel rpm on the vacuum manual.
Will my pump run dry if the main drain side is closed off 75% and the vacuum clogs? How limited will filtration be if it’s mainly coming in from the vacuum line at 1000rpm for 8 hours a day? Is there a better way to configure this?
