My pool closing cost was included in the build so they closed it last year. I was not able to be there so I'm not sure how they closed it. They charge $315 so I am trying to do it myself this year. I lowered the water to about 2 inches below the skimmers but could not get a shop vac to suck the water out of the skimmers. I also tried connecting the kids' bounce house pump (which blows a TON of air) and my commercial backpack leaf blower to the drain line in the cartridge filter to no avail. My pool is on a hill and approximately 5' above the equipment pad, which is also about 40' away. I also have a check valve on the return line going to the main pump, but no check valve on the waterfall pump.
What is the best way to blow water out of these lines? Should I order a Cyclone pump? Should I buy some fittings for my pancake air compressor and try to use the drains in the pumps? Where else can I connect an air supply source? I'm pretty lost here because I'm trying to push water up hill and like 40'+. I've done lots of searching but I am having a hard time finding others with a situation like mine. Any help is greatly appreciated!
Here is a picture of my equipment pad. The right hand side is the filter pump where the check valve is, on the line leading right into the pump from the pool. The left hand pump is for the waterfall.
