waste said:Closing off the other valves (so as not to waste the antifreeze in them) is a very good idea![]()
You are lucky to be able to do that :!:
I'd just 'reblow' the MD and forget about it for the winter![]()
If you still are worried about it, either ask more here or just work your way through a 6 - pack until it doesn't bother you :lol:
Hope to see you over the winter, if not, we'll see you next spring :-D
As the water gets colder, the pH will rise, all else equal. So the CSI won't decrease as much as you think as the temperature drops. If I use your starting numbers, then I get a CSI of -0.17 using my spreadsheet and if I only change the temperature down to 8ºC then the CSI drops to -0.32 but as the temperature drops the pH will rise to 7.83 so the CSI will actually only drop to -0.20.jwfrank said:I have noticed with the Pool Calculator that water temperature influences the CSI, all other variables staying the same
With my pool chemistry, cooler water temp of 2 degrees centigrade increases acidity by .03, according to Pool Calc
Question: given the above, and given that winter water temp will be in range of 6 to 12 degrees C, should I build this into the pH and TA target measurements at which I leave the pool when I cover?
In Sacramento (similar to or slightly warmer winter temperatures than in central Georgia), the booster pump & pool cleaner operate when freeze protection mode kicks in at 38 F or so. On my system it doesn't have to be set up this way; in fact, when the temps are low for days at a time I try to remember turn it off (to save electricity and reduce the noise from having 2 pumps running at 3 AM.) In my area, it's usually the overnight lows that trigger this. Day time temps rarely do. I have wondered whether freeze protection is really necessary -- in Sacramento or Macon.kenmccall said:I am not going to close my pool and I know I should run my pump when it nears freezing temps. Should I also run my Booster Pump?
Is this an above ground or in-ground pool? Are you planning to test/treat the water after you cover it?farmerselectric said:I live in Arkansas and we do get below freezing but not for a long period of time. I plan to cover the pool and turn on the pump when it gets close to freezing. My question is what do I need to add before I put the cover on. As of now, the chemicals are where they need to be. Thank you so much for all your help.
ok, ive looked at this thing 10 times now, and im clueless as to what the heck it is... please explain lolX-PertPool said:here are some pictures of the ways we do things.
