For me, it's easier to maintain and test with no cover at all. I have to get out a lot of leaves but it still works best for me not to cover it. Our climate is quite similar to yours.only with some sort of cover other than the solar one.
Johnny B said:5- Poolmom wrote: "I haven't used Polyquat it the last two winters and had no problems, but every pool is different. If you do use it, you add the PQ first and it will consume some of the chlorine, so after you add the PQ then you wait a day to shock, before you winterize."
This conflicts w Jason's sequence on page 1 of this thread. Jason likes to shock then wait a 1-3 days till the Cl level falls half way back to Normal Level then add Polyquat.
Good point. I think we will start out with no cover.duraleigh said:For me, it's easier to maintain and test with no cover at all. I have to get out a lot of leaves but it still works best for me not to cover it. Our climate is quite similar to yours.only with some sort of cover other than the solar one.
The light will likely be below water if it is at the level I have seen all othe rlights. Be sure you read this & other threads on closingTheExecutive said:I have a few questions:
1. I only have one skimmer. So when I blow out the pipes I just stick the hose in the skimmer right?
Yes
4. I have a light in my pool, do I leave that submerged under the water, or do I have to drain below it?
gkruske said:Closed yesterday, for my first time. Took me the majority of the day, by myself. I felt that I was thorough, although my compressor had a hard time. Ran most of the time, but have figured another route that I could take next year.
Now...to my question. In my final inspection to make sure that all valves were open, except the main drain, I accidentally turned the main drain valve (after it was successfully blown for about 45 seconds).I realized my mistake after about MAYBE 5 seconds, and closed it fast. I was getting anxious to finally finish, and was moving too fast.
How much water came back up in the line, and how is this going to affect things? I considered hooking back up, and blowing the line again, but that would have forced the antifreeze in the heater and above-ground lines out thru the drain.
duraleigh said:
