I'll start off by conceding this thread is a bit presumptive as I haven't done troubleshooting yet. Hurricane Florence came through here this weekend (technically she's still here). My pool water is clear, but there are lots of leaves and small twigs in the bottom of it. The last time my pump ran was Thursday night. We lost power and it was off overnight Friday. My pool pump is on a circuit that is protected by a GFI outlet. The outlet is tripping. The wiring from the outlet to the pool pump timer is through conduit and is well wire so it is tough stuff. I suspect the problem is likely wet connections either at the box with the outlets for the pump and SWG, or the timer. It hasn't quit raining enough to troubleshoot yet. If the problem is actually the buried wire, is it an issue if I simply put the cover on the pool and clean it out in the spring? I was planning to put the cover on this weekend, except I didn't want the wind to wreck it so I figured I'd close the pool next week. I see about replacing the wire later this fall or early next year.
