I am closing my pool myself for the first time and pretty familiar with the plumbing but it is a cluster back there.
I watched the last company close everything so familiar with all the equipment and drain plugs but I did not see them blow out the lines.
I purchased a cyclone to do this but I wonder how to blow out the lines.
Plan on connecting the cyclone to the inlet (suction) side of the pump and blowing the skimmers/main drain from there (after draining pool). Then my SWG is right before the return so when I remove the well I thought I could blow the returns from there?
I assume this is the easiest way or am I misunderstanding/missing something?
I have a sand filter and heater and this way I won't be blowing anything into that area and assume gravity will drain these enough?
I am sure I will run into issues so wanted to start a thread with the questions I have so far.
Also does the cell come out of the housing on a Circupool RJ60?
Thanks!
Thanks!
