- Feb 6, 2018
- 184
- Vinyl
- Hayward Aqua Rite (T-15)
My pool is currently fully closed. Last year (the first time I closed it), I opened it the first week of April but it was too cold to go in the entire month and a ton of pollen dropped in. So this year I was going to open it the end April/beginning of May (although if the temps get too high I may have to open it with the exception of removing the cover to keep the pollen out).
I peeled the cover back (looks nice and clear) and took a sample. Everything was in band BUT my pH was 7.0 (was in band when i closed it). I double checked with a test strip which said 6.8. Only thing the water is touching is the vinyl, steps and metal step railing. Do you think I need to take any immediate action or should I just monitor it? Thanks!!
FC=8.0
pH=7.0
Alk=60
CYA <30
Cal=150
FC=8.0
pH=7.0
Alk=60
CYA <30
Cal=150
