Hi there,
Closed our 27' salt AGP a month ago. Drained water down to skimmer, covered with float, back pumped some water on top to reduce wind issues. Skimmer is open (overflow drain) but return is sealed.
Water level was and remains a few inches below the return. We have received a lot of rain; all of my neighbors have had to drain some off the top but not me. We have clay soil and there are spots close to the pool that have standing water; but there are spots away from the pool that also have standing water. Rain is such that with the clay I am not sure if the water is rain or pool water. Pool store referred me to a diver / leak fixer that may be done for the season (upstate NY).
I read the pool school leak article and and prepping for the bucket test
Questions:
John
Questions:
- If water holds steady at the lower level should I wait until spring? Worried if there is a tear I may get ice between liner, insulation and metal sides.
- Thinking of uncovering for visual inspection near ladder. Pool area high and dry prior to closing but weather confuses things.
- Does food coloring wear off? Like should I dye bomb the pool to check ground water or will I have dyed water in June? Pool School article seemed to show dye used sparingly, not dye all water.
- Maybe water on the cover has pushed down, forcing water out the skimmer, then as water on the cover evaps it drops down below skimmer again (my favorite answer)
John
