- Feb 6, 2018
- 188
- Vinyl
- Hayward Aqua Rite (T-15)
I’m curious what you think about a hybrid closing I’m thinking about:
For 2 winters (in Virginia), I’ve left the pool open all winter. However, I spend more time maintaining it in the winter than I do in the summer = Constantly scooping out twigs & decomposed leaves, empty skimmers, run cleaner, weekly FC/pH testing, draining to maintain level, clean filter, $$ for running the pump & chemicals. And we never go out back to even look at it (a common response from those who leave their pool open).
So last winter I fully closed it which was nice initially. I was forced to open it at the beginning of April since pool temps were >60F and I needed to get my SWG running. We don’t go in it until mid-May and the pollen was terrible up until that point which again resulted in lots of maintenance for 6 weeks when we weren’t even using it.
SO, for this winter coming up, what if I adjust chemistry as if I was closing it, adjust level to the arrow, set the pump not to run daily but powered on for freeze protect and then just put a solid cover on? This way, I could leave it closed through the pollen time of April/early May when the temp is above 60F increasing FC demand, but I could start my pump/SWG up and start analyzing the water. (I’d also check pool level periodically throughout the winter and keep the cover drained). Does anyone see a negative with my plan?
