Does anyone see an issue or problem with leaving the spa open longer than the pool?
We prefer the Spa during 40-55 F temperatures, as opposed to the summer.
I closed the pool, using the usual techniques...blowing out the pool returns thru both skimmers, RV antifreeze, Gizmo in skimmer, and using adjustable diameter freeze plugs for the three returns back into the pool while the air if coming out of the return. The Jandy valves from the skimmers are then closed, and the Jandy return valves into the pool returns are also closed, and I pull the Weir doors out. Ran SLAM before all this, and balanced around 7.2-7.4... The only open lines left are from the spa bottom drain and to the spa returns. I have the filter and heater still operational as you'd expect.
We closed the pool earlier than normal this year because quite honestly, it's been way colder here than normal, leaves are falling early...and we are doing a nearby backyard wood to Trex decking replacement project next week that makes sense to protect the pool.
Thanks
Thanks
