- Aug 31, 2019
- 298
- Plaster
- CircuPool RJ-60 Plus
Hello TFP,
So I think I have a clogged vacuum port. For the suction side I have 2 skimmers, 1 vacuum port, and a main drain (technically 2?). I noticed my Poolvergnuegen vacuum wasn't running so I started looking into it, here is what I've done so far.
I've read a bit about this on TFP and elsewhere and I know the recommendation is to use a hose with a rag or with a water bladder/blaster but before I do that I found this video. He mentioned while the pump is priming you can turn the valve to the clogged port on and off a couple times to see if it dislodges the debris. My question: Is that safe, I don't want to cut off all suction/flow from the suction side of the pump?
If I can't use the method in the video of turning the valve on/off, is my next best bet using a garden hose with a rag or a bladder/blaster?
Thanks!
- Checked pool hoses for debris, non found.
- Checked for debris in the vacuum , non found.
- Verified the vacuum moves freely, looks good.
- I then checked to make sure all the valves were in the correct position, every looked good.
- I attempted to turn off all valves except for the vacuum port, and the pressure on the filter dropped and the pipes started making tons of scary sounds.
Thanks!
