I’m fairly new to following TFFP. I have an above ground vinyl pool with approximately 13,000 gal.
FC -5
CC-.5
PH- 7.6
Alk- 80
CYA- 40
Every year I’ve been plagued with algae and so far this year I haven’t had any issues with algae…yet. I was adding the chlorine According to the app to reach 5. But by afternoon it was down to 2.5 and this was when it was not too hot here. I was worried that wasn’t high enough to keep the algae away so per suggestion on this forum I raised it to get to 9 ppm knowing that it would drop some. I add the liquid chlorine in the evening an I tested FC in the a.m. it didn’t drop but by late afternoon it dropped to 5ppm, which is ok but is it normal to drop that much? Should I up my CYA? I’m having to add quite a bit of chlorine each evening . Thanks
FC -5
CC-.5
PH- 7.6
Alk- 80
CYA- 40
