Thank you for posting the rest results. Your CYA of 50 is actually really good right now, but yes, at some point in the near future, not now, we'll add stabilizer.
For now - do you have any muriatic acid or dry pool acid on hand to lower the PH? In PoolMath, if you make sure your gallons are correct, and put 8.0 in the "Now" column for the PH row and the put 7.6 in the "Target" column for the PH row, then press "Calculate" it will tell you how much of each type of acid is required. Keeping the PH between 7.2-7.8 makes sure your bleach/chlorine is extremely effective. On the FC side of things, since your pool is always losing FC to the sun, to leaves, bacteria, algae, etc. if your pool is using more than your IC40 is generating then you're on the expressway to algae if you don't add more FC using bleach/chlorine.
According to [FC/CYA][/FC/CYA], for your CYA of 50 you really want to bring your FC back up to 8 whenever it goes under 6. To really make sure you've gotten rid of all the algae and bacteria from the swamp, our SLAM Process process suggests you bring your FC up to 20 using bleach and keeping it there until you pass all three SLAM Process ending criteria listed on that page. Our members find that after SLAM Processing a swamp, their pool becomes very predictable and they can dial in the SWG and/or bleach additions and keep their FC in their target range very easily - without many, if any, surprise FC drops down towards zero.
First, thanks so much for your detailed instructions, they are very helpful. I need to read the SLAMMING process articles again to find out what the three criteria are to end the process.
I do have muriatic acid and PoolMath says to add 20 oz, which I will this morning.
I put my last gallon of bleach in last night. I will first test this morning and then I will go buy more today to ensure I am keeping the FC up.
