Hi Curtis.
I hate the AA treatment too and don't blame you a bit for not wanting to do it, as I was in your shoes once
So, if you're willing to experiment, I will tell you what I do instead to handle iron staining, which I'm 100% confident that is.
But bear in mind this is not the "official" preferred treatment of TFP, okay?
First, download this PDF to do the sponge test -- its easy, especially since you'll test on the steps. It will give you a ballpark idea of how much Metal Magic it will take to lift the stains.
http://www.proteampoolcare.com/images/uploads/MetalMagicSpongeTest.pdf
Metal Magic is a metal sequestrant that will prevent stainng from iron. It does wear off over time, but in my experience, once you do the levels according to the sponge test, you will only need to add a little once a month. If you cent find any locally, its also sold online at
Pool Chemicals, Hot Tub Chemicals and Supplies | Pool Geek
If you're NOT on well and the iron is from the swamp sludge, over time with backwashing if you have a sand filter, you will slowly be reducing the iron level. Once its below .3 ppm, it won't stain.
If you are on well, I'll give you more tips later but I'm on a quick break from work right now because Matt asked me to chim in
Hope that helps!
