So my pool has a vacuum inlet, 1.5" NPT I'm assuming. Hayward vac-lock doesn't catch. It'll go about 2-3 turns then go off the rails and get pushed out. Taking a close look, it seems like it's calcified pretty bad. Previous pool person didn't take good care as there was calcification all along the walls around the entire pool, and where the spa spills into the pool, a thick line of it. After 6 years of better maintained pH, a lot of it is actually gone or thinned out. But the ones in the threads remain.
Other than buying a $50 tap set (if that is even a good idea) any ideas on how to clean the threads? Metal brush and even a pick hasn't worked. Stuff is rock solid. SoCal water.
