Cleaning out dirt/algae buildup
dmat3889
3
BR La
So not my pool but im at a loss of how to help. Friend bought an above ground 20' dia x 4' intex pool. The pumps were replaced due to total lack of power to a 3/4 hp one with a sand filter.
We keep doing our best to test and treat his pool water but he keeps having dirt building up on the bottom. The valve is only a 4 way with no waste feature and the connection points arent made for any hose hookups.
I'm used to dealing with my inground pool that I can vacuum out easily so im not sure what we should be doing here. The buildup is just to much and im at a loss of how to remove it other than draining the pool which is what he has been doing.
This is in louisiana if that means anything.
Tcadwall0
206
Charlotte, NC
Fiberglass
Pentair Intellichlor IC-20
I had an intex above ground, and because the suction side 'ports' were so small, I jerry-rigged a reducer and had to cut out some of the 'strainer' built into the port with some snips. Then I could attach a normal vaccum hose to it, and it worked great for years.
Takes a little commitment and creativity, but it can be done. I wish I had a picture of it, but I sold it recently.
But there should still be a waste on the sand filter, right?
