- May 30, 2012
- 2,228
- Vinyl
- Hayward Turbo Cell (T-CELL-5)
I normally break down and fully clean my EC-40 each fall, storing it for use in the spring. My normal process is to soak my tube sheet assembly in a bucket full of water and Oxy Clean overnight, and then hose it off. They usually come out bright white.
This year they are staying dirty grey / brown.
A number of questions
- They look clear, just discolored. Am I overthinking things.
- Will an acid wash help (if so, what is the recommended strength). As an aside, this is the first time in 5 years I have had any significant scaling in my salt cell, necessitating an acid soak. Maybe something is up with my pool. It is a new pool this year.
- If I do replace these, do they make just the "socks" for the tubes, and not the whole tube assembly (sock with inner plastic tube). My plastic tubes are just fine, I would like to just replace the socks on them. (because the tubes are not cheap)
Thanks
Thanks
