I have a new cleaner (two months old) that has been doing a great job. About three or four days ago, I noticed it was not running during the scheduled time (I have an Easy Touch pool/spa control system and use the Pentair ScreenLogic app to create/adjust settings). The pool pump is set up in the same fashion and is running perfectly.
I’ve deleted and rescheduled the cleaner circuit schedule, this did not solve the problem. I’ve hit the reset button on the outside panel, this didn’t solve the problem. I’ve also tried to manually turn on the pump via the outside panel and this didn’t do anything. Also changed the egg timer for the cleaner to 0 minutes. I’ve gone outside and it seems the cleaner pump does try to turn on but for a few seconds then quickly turns off.
Any suggestions for other troubleshooting steps?
