Couple quick questions on Doing the SLAM protocol & overnight free chlorine test. The SLAM says to leave my pump running 24/7, I have a spillover spa so wont the aeration of the waterfall reduce my chlorine levels? do I leave the pump running overnight when doing the OCLT for this reason or should I switch my valves around so to not create a spillover? Also if my morning test is an hour or so after sunrise but no direct sun on pool will this make a difference? I ask because my pool started off pretty clear & has been crystal clear without any cloudiness whatsoever for the entire day but free cl still dropped from 21.5 @ 9pm to 14.5 @ 7:am, both tests read cc at 0.5
other #'s
calcium hardness 550
total alkalinity 90
CYA 55
Thanks again.
other #'s
total alkalinity 90
CYA 55
Thanks again.
