Hello looking to add a vsp pump. Does any one have feed back on circupool pumps? Thanks
No, the lower THP pump is not more efficient. Again, an artifact of the way WEF is calculate. When running at the same flow rate, the larger THP pump is more likely to be more efficient than the lower THP pump. This is usually the case with pumps in the same pump product line.For example, the CircuPool SmartFlo 2.0 has a WEF of 8.4 vs the 3hp model has a 7.5 WEF. Would the 2.0hp be the more efficient pump for typical low speed circulation on a C-class curve? I'd still need to determine if 2hp would be enough for my future build, but would think so.
