I’m looking to take advantage of Black Friday sales and pick up a SWG, and from reading through the forums, it seems the CircuPools are well reviewed. After looking at the sales at discountsaltpool.com…
I’m debating if with my 21,000 gallon pool, if I should go with an EDGE-25 with a 7 year warranty, or an SJ-45 with a 3 year warranty. Both are just under $1000 with Black Friday savings. I realized with an EDGE-25 I may get shorter life out of the element, than going with a higher capacity unit, but I assume if it stops working before 7 years, their would be a pro-rated refund. Where as if I go with a SJ-45, it may last longer, but its warranty ends 3 years sooner. I know everyone says size the system 2x larger, but I’m not sure if going with a 2x capacity but lower warranties systems is worth it?
Any thoughts or opinions. I did see that one poster with a similar pool in similar climate was running their EDGE-40 at about 30%, which would mean for my pool I would be running the EDGE-25 at about 50% power if I needed a similar amount of chlorine generation, so it seems the EDGE-25 would produce enough chlorine. So the really question is if I should trade sizing (which would me longer life) for warranty? I’d appreciate any opinions people have.
