Circupool RJ60+ Plumbing Advice
reggiehammond
2,260
Fort Worth, Texas
CircuPool RJ-60 Plus
First post -
I've had a 30k gallon plaster pool in a home we purchased in 2016. Initially I took care of the pool for the first year, but second baby arrived, and we hired out a service. Late summer algae issues the past 2 years and high CYA led me to let the pool company go (same song and dance as most everyone here).
Did a 80% drain last week and refill and have a Circupool RJ60+ arriving in a few days to bring the a SWG online.
I've recently replaced a Polaris 3900 with a Pentair Warrior SI; removed the PB4-60.
My plan, in photo attached, is to simply cut the return at concrete line, 90º up then make a straight run to intercept the existing return pipe. In this area, I'll install the SWG.
General question is what to do with the Booster return line to pool. I'll be removing the section I put in dotted line; but the return line that'll be loose. Do I just cap it and leave it be?
Anything I may be missing in this plan? Thanks
Sounds like a good plan.. I would use the booster line as another return line, should lower your pressure some :)
you really do not want to cap it as it would be a constant source of algae with no running water through it...
Ah; good idea. Hadn't even considered turning it into a return line.
Reactions: cowboycasey
Got the unit installed today; SWG right after the 90 off the filter, then down to a T and flow switch. Wired to my pool timer to the former Polaris timer and off it went. Really easy; only work to do now is figuring out how to protect and route the flow switch cable and the excess SWG power cable.
Pretty cool to see the bubbles rushing off the cell.
