I'm planning to install a Circupool Edge40 this week and could use some help on wiring and plumbing.
Plumbing: We have a simple setup: no heater, no spa, no water features. There is plenty of space to install the unit and the flow switch. The complication is that both the former owner and myself have ignorantly installed dwv elbows numerous places. To get rid of them will require replacing almost all the plumbing that's more than 6" above the ground. How important is that?
Wiring: Prior to installing the VS pump, I used the pictured timer to run a 3/4 hp single speed pump. The VS pump is still wired to the ancient timer, the timer (3rd picture) never goes off and the VS pump is scheduled to run 24x7. I plan to mount the control box to the right (after replacing the rotting 2x4!). I could easily connect the control box to the 110v power in the nearby junction box (close up in the 4th picture). That, however, is on a separate circuit from the 220v line running the pump, and thus I would be dependent on the flow switch to turn off power to the SWG if something went wrong with the pump. Would you suggest a different wiring setup?
Additional consideration: I suspect we will be moving in a couple of years, so our time horizon on improvements has shortened...
Thanks for your help.
