Hello folks, after reading many threads and community recommendations here for CircuPool, decided to go with the Edge 25 and completed the install last week (my first time for any real PVC work ). The system does generate chlorine but not to their advertised levels. More like 60-70%.
On the day of testing, I ran both my pumps for 2 hours without the SWG ON after dusk. Took the first FC reading. Then ran SWG at 100% for 4 hours. And then let both the pumps run again to circulate without SWG to take the final FC reading.
Initial FC reading: 3.2
SWG runtime: 4 hours at 100%
Final FC reading: 4.4
But if I use pool math, FC should be around 5.2 for my 12k gallons pool.
Since the whole test ran on night, I assume there wasn't any chlorine consumption. Also nobody was in the pool for last 2 days before this test. Other numbers:
Ph: maintaining at 7.6
Salt: 3600 ppm (their recommended level is 3500)
Alkalinity: 110
CYA: 70
Calcium: 290 (from 2 weeks ago but shouldn't have changed much)
Am I doing this right? Did I get a lemon? Has anyone else measured their CircuPool's output?
Alkalinity: 110
CYA: 70
