Hello All,
Thank you in advance for any and all suggestions. Relative newbie just trying to get a firm grip on circulation in attempt to avoid dead spots and increase skimming action of the pool surface. The pool design, return/intake placement, etc was not my choice as the pool was here when we bought the home. Please reference the attached diagram (as crude as it is, and not to scale).
Before I started messing with eyeballs, etc the circulation counter-clockwise & ok at best. Dirt, leaves, etc would tend to find their way to the pool floor near the spa alcove. Additionally anything that could float (thermometer, tab dispenser, toys would eventually find their way to the waterfall and not be able to escape. Also, of the three returns only the one closest to the spa was directional. It looks like a bottle cap with a slit, and the slit is angled down, away from the waterfall.
Next, we had a pool repair come to look at the light and he suggested I replace the return closest to the steps with an eyeball to increase the flow/pressure of all returns (including the spa), thus improving circulation. This did not improve circulation in that the dead spot was still present and skimming did not improve. The only that improved was water coming out of the returns (the spa too) seemed to come out with more force.
FYI - the return closest to the steps is closest to the pump and seems to be the "main"return. Also, on the diagram, the pump is approximately 6'-8' to the left of the skimmer.
At this point I tried to adjust the direction of the returns but to no avail. I am hoping someone can provide some insight on what type of return coverings I should use and where to point them, or simply let them shoot straight into the pool. Sadly I am beginning to think the pool design (alcove away from the main return) will prohibit much improvement. The main return does have enough force to reach the opposite side of the pool.
So, thank you VERY MUCH to anyone that has taken the time to read this. I am very grateful for any input.
BE SAFE !!
WOLLAM
BE SAFE !!
WOLLAM
