Circuit Board Aquarite Goldline SWG
Henry M
196
Coral Springs, Florida
Install the fuse, jump the legs together and see if the display comes on and gives you diagnostic readings.
Leave the switch in the Off position until you get the new thermistor installed.
When the new thermistor comes in, install it and you should be good to go if the display readings are good.
Thanks for your reply. I'm assuming that I need to turn switch on to see if display/diagnostic readings show, and once they are shown (if they are), then I should immediately turn the switch off. Am I anywhere near correct?
Henry M
196
OK. Will give this a go and post again.
It works!!!! All diagnostics show on display panel. "Thank you" is an understatement. No way would I have ever been able to do this without your help. You helped me add a dimension of knowledge I've always avoided because anything to do with electricity is intimidating. Seems it was the fuse all along. Next step will be to solder (also an intimidating skill) in new thermistor. So for want of a better term: Many, many thanks!
Reactions: JamesW
JamesW
22,141
There are plenty of videos on YouTube about soldering and desoldering that should be helpful. Mostly, you just heat up the solder with the soldering iron and suck it out. Install the new thermistor and solder it in place.
JamesW
22,141
That brings up the question about why the fuse failed.
One thing that can cause the fuse to blow is if you add salt while the cell is on.
Did you add salt right before the fuse went out?
Henry M
196
I'm not 100% certain, but I don't think so. I'd read somewhere about this same thing. I did inspect & clean the cell, though, before the fuse went out.
Reactions: JamesW
Henry M
196
The board seems odd in that it does not have the heat sink pads?
Will the AS32 thermistor fit any of the two silver spot?
For example, can you use an existing used spot and an unused spot?
It seems like some combination would work with the AS32 thermistor.
mainboard-jpg.170156
At TH1 (lower right corner in photo) are bare terminals for thermistor. Right next to them are holes, but they are soldered closed. Can they be unsoldered & a new thermistor installed in those holes?
JamesW
22,141
I think that the two holes right next to the existing legs can be used for the thermistor. Those are the holes that I thought might take the AS32 thermistor.
You should be able to remove the existing legs or use the unused holes.
Henry M
196
Tried soldering new thermistor on existing legs, but doing so requires more skill than I have. So thought about desoldering those unused holes & just soldering in a new thermistor.
JamesW
22,141
Get some needlenose pliers and gently pull on the leg while heating the base of the leg with the soldering iron.
Or, you can use the new holes. Just heat the solder and vacuum it out while it's liquid.
JamesW
22,141
If you're not good at soldering, maybe run the board and thermistor by an electronics repair place. They should be able to replace the thermistor in about 5 minutes.
C0d3Sp4c3
116
NorCal
Those holes right next to the existing legs are predrilled to take the SL32 thermistor. But yes, you can use either the existing or the unused holes whichever is convenient for you.
Keep in mind the original thermistor is 25mm in dia as compared to the SL32 at 31mm in dia.
Henry M
196
New SL 32 thermistor soldered into place. Upon replacing wires (I doubled checked: all colored wires & in the right colored terminals) & turning unit on, I get: 1) no display; 2) all LED lights quick-flashing in unison; and 3) a loud tick-tock type sound. Still no function. I am at complete loss.
JamesW
22,141
Probably got a wire left out or in the wrong place.
Do you have a picture of the board and how it's wired?
