- Mar 13, 2021
- 4
- Vinyl
- CircuPool Edge-25
I purchased a 21x52 Saltwater AGP. My pump is the AquaPro 1.5hp 2 speed. The pump does not have its own timer for the 2 speeds. Do you have a recommendation for a timer, which is needed for the saltwater generator? From reading the forum, it sounds like I need one that has SPST in order to use both speeds. I have a vac that will run independently. Should I run the pump on low all the time or switch from low to high?
My electrician is suggesting a separate 220 hookup for the entire pool setup. I'm looking for advice on how to run the system economically! Thanks so much.
