chlorine usage excessive?
Ricker
Active member
Jun 2, 2021
33
Toronto
Is it normal that my chlorine drops from 5ppm to 1 ppm everyone 24 hours. We only have 2-3 bathers for about an hour. We do get a lot of sunshine however. Does alkalinity affect chlorine? Last time I checked it was about 85. Im using about 2.5 chlorine jugs (3.6L 10.8% chlorine ) per week. My CYA is 48. pH at 7.6-7.8.
2-4 ppm FC loss per day is normal. This is peak summer.
You should not be letting your FC get that low. At a CYA of 50, the FC should stay above 4 ppm at all times.
Alkalinity has no effect on FC usage.
Not sure how you're testing as no mention in the signature of a kit. CYA is called 50 if you're doing it right but target FC for 50 CYA is 6-8 so you're in danger keeping it that low. You need to do an OCLT to see if there's already something in the water called algae eating at the chlorine.
