I use a TF-100 test kit. I'm getting different Cl test results from the chlorine drop test and the included K-1000 vial test. I use the K-1000 color test daily and have performed the drop test twice now - the drop test results have shown FC far higher than the K-1000 readings.
2 days ago my K-1000 showed Total Chlorine midway between the 3 & 5 color standards. Just for kicks I performed the drop test - took 14 drops for the solution to turn back clear, = 7ppm. CC was zero giving TC = 7.
This morning my K-1000 showed a slightly darker gold/yellow than the highest standard of 5. I ran another drop test and this time it took 24 drops = 12 ppm. CC was again 0, giving TC = 12. Ran a 2nd K-1000 test to verify - this one showed similar color to the first one.
As an additional test, I used a Poolmaster kit my wife bought last summer. While it may be unreliable, the test color appears between 2-3.
Notes:
The TFP Chlorine/CYA chart for non-SWG shows Target FC of 4-6 for CYA of 30, 5-7 for CYA of 40, and 6-8 for CYA of 50. Since the K-1000 only gives TC results to 5 what is the best way to perform daily tests??
I have no chlorine smell, and the water doesn't burn skin or eyes. Surely the drop test results are wrong. Any idea why this would happen? I use the SpeedStir. My reagents are from last summer, but have been stored in a cool, dark place and aren't yet a year old.
Notes:
- my pH is low because I'm in the process of lowering my TA. TA was at 400 when I filled 5 days ago and it's now down to 260 (well water). Running a homemade bubbler.
- CYA seems to be creeping up, but it may be due to subjectivity in test results or use of trichlor. I recorded a reading of 35 a couple days ago and today recorded 50.
- I have slowly increased the FC levels over 5 days. Was at 4 three days ago. Added bleach a couple times and use chlorine pucks (which I removed this morning).
