- Sep 17, 2022
- 101
- Vinyl
- Pentair Intellichlor IC-40
Hi all
Opened the pool a couple weeks ago. Just starting the tfp approach.
I have a swg and an automatic pool cover. The pool stays covered when not in use. I do try to open it up once a day just to air it out.
My chlorine goal is 4 generally. It seems that every time I check the pool I’m at 3. Still an ok number. The swg is set to 10%. This is higher than I have had it set in the past.
So I guess my question is. If I test my pool after sunset. And it’s 3 Fc. Shouldn’t the Fc be higher if I check it at sunset the next day having not opened it? Is my salt cell starting to go? I used to keep the swg at like 4%.
Just a bit confused as to what is happening.
