We have a brand new pool, first filled on 12/4/2020. I just received my TF-100 test kit and used it for the first time yesterday. On the Chlorine Drop Test, after adding the scoop of R-0870, the solution did not turn pink. (Not surprising because someone from the pool company turned our automatic chlorine down from where we had it.) Anyway, Step 3 says to add R-0871 one drop at a time until the solution turns back to completely clear. Is it OK if the solution is white (opaque)? I added a lot of drops and the solution never turned clear. What did I do wrong? Should I have stopped after Step 2 since it showed no chlorine? Thank you
