Earlier today, I measured my CL and pH with the Taylor kit (DPD-OTO) that comes with the TF_100 and it looked like about CL 4-5/pH 7.5. I decided to check it with the powdered R-0870 / R-0871 method. Normally, when you get to the correct measured level of FC, the sample goes perfectly clear...Completely clear, like water. What I noticed today was around and beyond 4.5 ppm (meaning 9 drops), the sample never got completely clear and stayed ever so slightly pinkish/purple....much clearer than at the start of the test but NEVER WENT TOTALLY CLEAR. I tested it twice with the same results. I read other threads about it being cloudy....this is not the case...still has some color. In any case I have two measurements that indicate around 4-5....so I feel good about that.
Does this indicate my R-0870 or R-0871 is now expired?
