Just got TF 100 kit. Daily test shows 5-10 chlorine with color nearer 10. When tested with titration FC only shows 5. Total tests: FC 5, CC 0, CA 600, CYA 80,TA 110,PH 7.6, TDS 1500. Las Vegas water starts at CA 290, so hard to keep it down with summer evaporation. I see that with CYA of 80, I should keep FC at Min of 6 with Target of 9-11. should I only rely on titration for an accurate FC reading? Used TDS meter that I use to check my RO system for TDS reading. Planning on draining pool this coming spring for kool deck and light repair. When refilled I will be checking on RO treatment for pool to keep CA down.
