I think Durk's on to something. Don't worry about running your well pump long enough to fill up your pool. But, you can run it for an hour, can't ya?
Drain your pool an inch or three each day and fill it up for about an hour. You'll figure it out after the first or second time. Since your pool & mine are roughly the same size, I'm thinking you'll replace around 1,000 gallons each day this way. After 3 or 4 weeks, you should have the CYA level down to a manageable level. Measure the CYA weekly to check your progress.
A CYA of 50 - 80 will be cheaper & easier to manage (you spend less on bleach & have fewer gallon jugs to schlep.) A CYA of 30 - 50 is probably a better target, but sometimes you take what you can get.
Good luck!
P.S. - I'm pretty sure this will work. I've done the same thing, but without the draining part - I had a leak last year. Had to run the hose about an hour each day to maintain the water level. Over 2 months, my CYA went from about 80 to about 30 due to water replacement. And, I was using pucks (trichlor?) as my main Cl source the whole time.
Good luck!
