I'm having an issue with my Chlorinator. I'm using an IC40 that's about 15 months old. The problem started about a week ago. I can turn the pool off and flip the breakers off, completely shutting down the system. Then I flip the breakers on and start the pool pump.
Current water temp is 63.
The chlorinator has the following settings after start up:
- Sanitizer Output 60%
- Chlorinator Status
Cell Green
Flow Green
Cold Water Light not blinking
At first I see the following:
Flow - Green
Salt Level – flashing Green/Red for about 2 minutes
After about 2 minutes, the salt level lights change to a flashing green light (Flow still green).
Then after 3-4 minutes, the chlorinator shuts off (restart of system continues to run without issue).
Not sure what to do. Add salt or drain/re-add some water?
Any thoughts?
Thanks!!!
Cell Green
Flow Green
Flow - Green
Any thoughts?
Thanks!!!
