Dear Joyfulnoise and any Chemistry geeks @JoyfulNoise
Can anyone shed light for me here
K
Most agree a) pools need chlorine b) sunlight breaks down chlorine quickly c) a substance cya exists that can extend chlorine’s life up to 8 times d) as cya levels increase chlorine’s ability to kill and oxidize decreases dramatically.
e) FC = 7.5 % * CYA
So for Pool With 100ppm cya, unless FC is greater than 7.5%, a pool with 100 ppm cya has zero ability to sanitize until FC Levels exceed 7.5 ppm
Everything ok so far?
That’s the premise leading to my question
If cya (containing 3 carbon and 3 nitrogen atoms) holds chlorine under the CYA ☂ (cya hotel) for awhile -
Why then -when the CYA HOTEL (nitrogen carbon atoms) release the chlorine for active duty .... why does the chlorine not work as well ? Was chlorine 1) maimed in the initial CYA Bond? Or 2) is cya greedy and and still holding onto too much chlorine-even when pool is needing cya to release it’s bound chlorine to fight germs as pool is gaining additional contaminates.... 3)or does CYA release enough FC and chlorine is in top condition - but because FC spent too much time IN CYA HOTEL - did the bad guys have too much time to reproduce?
K
e) FC = 7.5 % * CYA
