So, I've been trying to clean mustard(?) algae from the walls of my pool, and the chlorine hasn't been cutting it.
Found my CYA level to be about 120, so decided to drain half the water to try to get it to a more reasonable level.
Have been maintaining 20+ ppm FC, but it's not taking out the algae. And I realize with those CYA levels I either need a lot more FC, or less CYA.
So at this point I've drained about 1/2 the water. And where the water is down, I sprayed bleach on the walls etc which immediately removed the algae.
But underwater, that algae remains. I know, SLAM it once I get it refilled..
But I was thinking, while the water was low, it would take much less chlorine to make a high concentration (albeit still has the undiluted high CYA).
Does it make sense to add a ton of bleach to the 1/2 drained pool, and try to kill more of the algae before I refill it?
Problem is I can't run the filter while it's only half full...
