I am trying to help my dad with a pool crisis.
Last fall his cover failed and let leaves into the pool it was a huge mess by the spring.
Pool is now free of leaves and pump has been running. It seems that no matter how much chlorine is added, it registers at zero. According to my Dad, he has put 40 cases of shock/bleach into it...yes 100+ bottles.
The chlorine smell is overpowering so I went and ran the test myself. 10 ml of water, heaping scoop of powder = not pink. I decided to check for combined chloramines, 5 drops of the 003 reagent resulted in the picture I have attached. I gave up on getting it back to clear after 10 drops didn't even make the slightest change where they hit the water.
Where do I even start to fix this? CYA was at zero and was brought up to 30 so far, plan on going to 50ish (saltwater pool).
Thanks!
Thanks!
