I have an aquacal heat pump/chiller that will not come on. It is set to chill mode. The Jandy aqualink remote is set to chill mode under menu>system setup. The display on the aquacal says no water flow and cool set point 70 degrees. I initially set it low in an attempt to get it to come on. The aqualink remote says chiller ENA. When I use the remote to turn chiller off and back on it is set at 100 degrees and I lower it to 70 in an attempt to get it to come on. Any ideas? Thank you.
