reggiehammond
- Oct 4, 2020
- 2,253
- Plaster
- CircuPool RJ-60 Plus
Can you test your fill water that would be used to top off the pool and post those numbers for CH? That will indicate how much water needs to be removed. Do you have a water softener? Can it be used to fill the pool?
Most folks in NV/AZ have hard water high in CH. Every time you fill for evaporation, you add CH. You eventually have to dump the water and start over, but with softened water, you can avoid.
Right now, your water temp is likely cool, so algae is less of a concern. But you have very low FC that needs correcting. Before you do a lot though, let's see how much water needs to go.
